Maxum21
- Mar 8, 2005
- 219
If you have easy access inside your bilge where the dipstick tube bolts into the oil pan, would that be an acceptable way to drain the oil? Or, could i end up dislodging a nut or something inside the pan resulting in a leak? You wouldn't need to remove it completely but just loosen it to allow it to drain. I have a spacious engine compartment in my 24' Regal and would prefer to drain my oil, but not if it's going to cause a potential headache. What do you think?
