Dave-R
- Mar 18, 2008
- 441
I am getting ready to launch my 2011 Cobalt 232. If all the stories about the boat are true, this will be it's second launch. She's all checked out and ready to go thanks to a lot of you on i-boats. The boat has a large swim deck, and the drive is limited to keep from hitting the deck. There is about 4 inches of clearance when the drive is full up. At that point the bottom of the Duo-prop is a lot closer to the road than I would like. I don't want to grind the drive when going through a dip, so I would like it to raise a little more. I could not see a mechanical device to limit travel. I have a feeling it might be controlled with the ECM. Anyone have an insight on this? I do have a Rinda diagnostic that I can use to change any parameter if that's the direction I need to go. As always, Thanks Dave-R
