Hello All! Long-time lurker, but this is my first question to the boating experts! I've got a 2006 Four Winns Volvo Penta 5.0 GXi (SX-M1 outdrive). I pulled the outdrive off for the first time because I felt a vibration at the end of last summer. My nephew came over and helped me because he's got a VP 4.3GL with the same SX-M outdrive so he had the alignment bar (he had changed his gimbal bearing out last year).
When we tried to check the alignment of my gimbal bearing and coupler, we tried running the entire range of the engine adjustment bolts, but we could never really get the alignment bar to go into the engine coupler like it does on his boat. We were able to tap the alignment bar before engaging it into the coupler and think we have it aligned, but the bar will only go into the coupler 5/8". We put a light coat of grease on there and could see how far it would go in.
After we pulled the bar out, we used a piece of thin wall metal conduit to just feel the splines, because it feels like the coupler is just too small for the standard alignment bar to fit. We found that there was a small ridge in the splines, like the alignment bar would hit that ridge and not go in any deeper.
Has anyone seen this before? What could cause the coupler splines to be too small and stop the alignment bar from going full-depth?
Thanks in advance!!
Thanks in advance!!
