Well, I completed the rewire, and a lot of other stuff over the winter. Got it done in time for the salmon opener last weekend and got out without issue. It was rough so never took the boat over 2800rpm for any amount of time.
Went out today, and on the way back in...same thing, fell flat on its face, then started right backup.
I've rewired the boat, gone through the fuel system, new alternator. The only thing I have not done at one time or another in this process is replace the distributor.
So the rubik cube of my boat continues.
I'm now leaning to the distributor because I have swapped the coil, Ignition module, hei wires, cap, rotor at one point or another.
The only other thing I can think of is an intermittent fuel pump issue related to the oil pressure switch. But it just feels like fuel wouldn't cause an abrupt stall, only to restart immediately.
Let me know if you think of anything.
Thanks!
