Folks,
Background which might be relevant...I have what was originally a 501, swapped out with an indmar 5.7. It has a Rochester 17052983, and an electric fuel pump. It has an electronic distributor. It has an engine mount filter, and an added racor. I have a perko switch too.
3 times in the past month, always toward the end of the day, running in with following sea, the boat falls on its face. The first time it seemed to die completely, then start right back up. The second and third time it continued to run, and after a few moments I could get back under-way. In each case I backed off the throttle and ran in just fine; under 2600 rpm.
I tried running the boat under different perko settings and it happened under all and 1.
I suspected a short in the auto bilge pump and replaced as it seemed to happen after a long day of fishing and using the wash down. No luck....still happened after the swap.
I checked the engine fuel filter, no water and crystal clear.
Today I will check the carb filter. 6 months ago I had the carb rebuilt as the float was sticking and flooding.
I have more details but this should get the discussion started. Your feedback is greatly appreciated!
