Sparky_1988
- May 14, 2016
- 17
Hey, gang. Thank you in advance for any pointers you provide.
Here's my dilemma... I just purchased a used 2003 Larson 190 LXi with a Volvo Penta 4.3 GXi-B with less than 60 hours on it. Boat seems to run well at idle and cruising speeds, but stalls and dies when slowly throttling up from idle (500 RPM) to around 900 - 1000 RPM. If I'm on the lake and quickly throttle up, it stutters for a couple seconds, but then takes off and seems to run well throughout the rest of the throttle range.
Other info:
Not sure, but the exhaust MAY smell a little rich, but I'm not sure.
Slowly backing down to idle from 900 - 1000 RPMs is smooth with no stutter. It also seems somewhat better if I throttle up under load vs. in neutral.
It has 3/4 of a tank of gas from last year that was stabilized when professionally winterized. I also put an injector cleaner in it and ran it about an hour in the driveway with the muffs on it with no change.
Any ideas? Do I just need to run it a bit? Thanks!
Volvo serial number: 4012080831
Other info:
