I have a 1983 bayliner Capri with the aq125a and 270 outdrive. The issue I am having is the helmet for my outdrive only has one bolt but it has 2 threads. I think I am missing the block for it but I can't find a part number for the block or the other bolt that I need. I am also missing the bolt on the right side that holds the pivot block in and can not find the part number for it either. Here are some pictures.
