BrandonW89
- May 2, 2016
- 2
3.0 Volvo Penta. Can anyone tell me or has anyone ever had problems with the nuts an studs vibrating loose on the flywheel and coupler I purchased this boat used an just from the looks of new hardware it looks like the engine has been pulled before for whatever reason. The boat run fine all summer last year til right at the end of summer one of the studs vibrated out and was rattling around in the flywheel housing. I pulled the engine an found two or three studs coming loose also so order new studs an nuts and replaced them an torque them using lock tite because it look like none had been used before. Long story short wen I put the boat in the water yesterday it run great for the first 2 or 3 hrs pulling knee boards but wen I took it for a lil cruise for about 10 or 15 mins down river at around 3/4 throttle wen I stop to turn around I could hear like a rattling vibration at low rpm an take off but sounded fine at cruising speed about 1/2 throttle. But by the time I made it back to the boat ramp the noise had got louder an could hear it at idle before I got it loaded it on trailer I could hear a noise like one of the flywheel nuts had fell off it sounds just like it had done before. I haven't pulled the engine yet but I'm bout 90% sure the same nuts have vibrated loose. My question is what keeps causing this is it possible that the flywheel could have got warped some how by previous owner maybe? Any info would be greatly appreciated thanks
