Fishermark
- Oct 19, 2003
- 5,617
My boat has the AQ131 (or 230A) with the closed cooling. I am curious as to what the normal operating temperature of my fellow iboaters is? Mine seems to run hotter than I would have expected. It runs close to 200 according to my gauge. The engine doesn't seem terribly hot when I lift the cover - no leaking smoke anywhere.
I just looked it up in the manual and see the normal operating range is 165-194 degrees so I guess I am okay, if on the hot side of normal. I have already put in a new impeller, so I believe I am okay there. Just want to see what other boaters experience with a similar engine temperature wise.
