1997 Regal 2200 LSX w/ 4.3 GL Volvo/penta. outdrive was working fine, thought might have issue with neutral switch at throttle. The wires that control the outdrive got pinched as I hit forward throttle. I think a fuse blew somewhere. took the throttle apart and yep, the wires had been chaffed and contacted each other. Even though I routed the wires out of the way and wrapped in electrical tape where wire was bared, the outdrive no longer goes up and or down. Any guess as to where the fuse may be in the circuit? thanks
