1983 Gamefisher (Sears) 7.5 Value?????
MGuckin
I confirmed the year thru pics of the plate. Above motor listed on EBAY. Supposed to run good. How high do you think I should go? No shipping expense. Motor is located about 2 hours from me so I could pick it up.
ob
Re: 1983 Gamefisher (Sears) 7.5 Value?????
MG,This is nada's guideline .I realize they seem to come in low on price often ,but thought I would post it to give you a starting point.Of course the final determination should be made on the overall condition and operation of motor.Good luck.<br />Model: GAMEFISHER-7.5 1983<br /> Motor Type: Gasoline <br /> Volts (Electric Motors): <br /> Thrust (Electric Motors): <br /> Horsepower: 7.5 <br /> Cylinders: 1 <br /> Start Type: Manual <br /> Dry Weight: 40 <br /> Power Tilt and Trim: No <br /> Low Retail: $40 <br /> Average Retail: $50
MGuckin
OB,<br />Thanks.<br />I know about NADA. Normally low<br />Is 1 of the links I use when others ask this question here.<br />Just looking for overall opinions on the motor.<br />Thanks,
ob
Judging by the price of new motors nowdays,if this motor was in good visual and operating condition I would pay $200-$250.Just my 2 cents.Availability of parts when needed may be an issue.
MGuckin
I thought of the parts problem also. Limited availability.<br />I did figure in the ballpark of $200.<br />Thanks again
NathanY
I had a 7.5 Seaking, which I think is the same motor, and I sold it for $75. The great people on this board helped me fix it. I would not pay more than $100.00 for it.
NathanY
That also looks like a Clinton Engine, which parts are almost impossible to find parts for.
b.gagnon
Master Chief Petty Officer
DO NOT BUY THAT MOTOR!!!<br />A friend of mine has one (assuming it is one of those air cooled ones) and They are not made very well, and don’t hold up in salt water. It was a lawn mower with a prop, and never operated anywhere near the same performance as my 19716hp Johnson.<br />I personally think you would be better off with a 1958 6hp Johnson than that motor!!!<br />And most times you can find them Cheep!
b.gagnon
Also all engine parts I ever needed for it came directly off the shelf of a mower shop!
