Montgomery ward sea king 7hp impeller
Arronh
I replaced the impeller and in my shop I was just getting a mist out of the telltale, even though it was pumping well when I hooked a drill up to the driveshaft. Is a mist correct for this type of motor? When I’m on the water it’s really tough to see what’s coming out if it’s just a mist. Also, the lower unit above the water line gets super hot. It sizzles the water when I splash it. Any recommendations or ideas? Thanks.
brim_buster
Is it a clinton made sea king? Got a model or serial number you can post
brim_buster
The water pump when working properly is only to cool the leg. Why its getting hot tells me something isnt in place like the water tube.
