Ok, So this is the same model number my father had when I was a kid. Model 025-3569 1951-53
I bought this engine on Ebay and was able to get running using mid 50's OMC coils, points and condenser.
She's running but no water is coming out of the upper exhaust and I don't remember a Tell-Tale/Pee hole.
I have drained and removed the lower unit. Oil looks good. No Water.
I cannot figure out how to remove the plates and drive shaft to get to the impeller. It is mounted on top of the plates rather than on top of the lower unit.
Any Ideas would be greatly appreciated.
Thank you,
Slimbob
Thank you,
Slimbob
