My sea king doesn't have the little door on the lower leg, to enable releasing the shifter rod from the head. How do I lower the lower unit to get at the impeller?
thanks!
When you get the powerhead off, you will encounter a carbon seal. That seal must be 100% good or engine damage will occur over time. Always replace the 303355 (18-2892-9) gasket and 303347 (18-7180-9) o-ring. You will also need a 303065 (18-2901-9) powerhead gasket.
