Edperfetto
- Jul 14, 2018
- 1
Guys, thanks in advance...been restoring a 1971 7.5hp gamefisher.
I'm down to hooking up the fuel lines and I'm not sure which one goes where.
I had one running from the onboard gas tank to the top port of the carb but nothing to the bottom port and the gas just poured out. Apparently, I need a hose from one of the carb ports to the alternate fuel port on the motor housing.
Does it matter which port on the carb I use? Can I run a fuel line from eithe tank to either port on the carb?
I wasn't really planning to use an external fuel tank.
I've been searching the web for images with no luck.
thanks!!
Ed.
thanks!!
Ed.
