Model #225-587503
I'm having trouble removing the "retainer" around the prop shaft. I have removed the 4 allen screws, but am at a loss as how to grab the retainer and pull it out. There is very little to get purchase on to pull. It's part 18 in the diagram.
I've gotten to this point by pulling the lower unit and replacing the impeller. When I was removing the impeller, I also pulled out the drive shaft. Now, the prop won't turn and I can't seem to get the drive shaft to grab anything down in the gear housing (just spins, and seem to go down too far to the point that the pin (key) no longer spins the impeller).
I read on another thread that the pinion gear may have fallen, and I'll need to pull the unit apart to check/re-align. I really can't see anything when I look down in the unit with a flashlight.
Total noob here. Any advice is appreciated!
