I'm new to this forum but have been teadinv as a guest over the past few years. I have a 93 regal valanti with Yamaha yems 4.3 sterndrive. This past summer the boat started slowing to 2400 rpm whenever steering wheel is turned at all right of center. At the same time the trim gauge will flash indicating leg is fully up even though it is not. My question is does anyone know if these engines are equipped with a safety slow the engine down if trim is up. I'm wondering if I have a trim sender wiring issue that could also cause the engine to slow down. Every time it happens, the problem remains until engine is turned off and then restarted. Then all good until turn right at all. Any ideas would be appreciated
