castrolina
- Nov 2, 2016
- 17
Hi all, I have a 1993 Cobalt 185 with a Yamaha sterndrive v8 5.0. I had a crack in the original mechanical fuel pump and needed a replacement but they are no longer available. I bought an omc fuel pump because the plumbing was the closest match to mine. I have read numerous posts about installing a mechanical fuel pump, pretty straight forward. In all posts and videos I have seen, the pump rocker arm goes under the pushrod, correct? That's how installed it, but I had a no fuel situation, so I checked the Clymer and it says to make sure the rocker arm rides on the pushrod. Am I reading this correctly? Also, can you hear the mechanical fuel pump when the key is turned? Any input appreciated.
