oldboat1
- Apr 3, 2002
- 9,607
I run a 1980 305 MIE inboard in an F26 Trojan. It’s original with a lot of hours (no rebuilds that I am aware of). I use it gently. But it has never run close to the rated 4400 rpm at WOT, and that should probably be addressed. I get about 17 mph at 3000 rpm, but that’s about it for both speed and rpms. The motor seems to be smooth at idle and on the top end.
The distributor appears to be a GM version with vacuum and mechanical advance. It’s my understanding that the vacuum advance is an idle advance (believe it works — canister holds vacuum, and I hear movement in the distributor when I apply vacuum). I’ve read that the mechanical advance mechanism can fail over time, however, and I’m wondering if that would affect rpm at WOT. (I haven’t physically checked the advance mechanism yet.)
I’m not a hands-on owner with this inboard — pretty good with old outboards, but not so much with inboards. I haven’t asked the boatyard to run a compression check yet.
Any comments or advice?
