Finally got my engine to start, however there was some noise going into forward or reverse (not sure if it's normal), so I removed a bold on the outdrive suspecting that it was the place to check lubricant levels. I removed the bolt and had water coming out. I tried bolting it back, but the bolt bolted to a non-stationary nut and now I cannot get it back on. I'm think I'm going to have to take everything apart. Oh, god! How do I get the bolt back on?
My engine is an OMC Cobra 5.7 Litre. Here are pictures of the outdrive where the bolt was removed.
Edit: The first image reads "Removed nut here," but should read "Removed bolt here."
