HI, every one, from a newbie!
I recently picked up a Sea Sprite Mark III Continental (1984) with an OMC I/O. This is my first boat. I have used boats before, but never with an I/O. The model #number on the engine, 990234E1, Identifies it as a 1977 120HP. It runs well (IF I jump start it), but as you can imagine, the ol' girl needs some fixin'. Besides the battery, the Bellows has tears in it, and the ball gears need replacing. There is a model number on the Outdrive, 983586, but I can't seem to find any info when I search for that number. I also could use a little help with terminology, as in Upper, Lower and Intermediate sections. I can guess that the lower Section is where the prop is, up to where it bolts onto what I suppose is the upper section, but what is the intermediate section, i.e. where does it start and end? Also, is a transom seal the same as the bellows, or are they two different parts. I'm sure I'll have other ?'s but that's enough for today!
Thanx in advance to anyone who can help!
