I pulled my outdrive (1989 Cobra on 5.7l) to replace the u-joint bellow and shift cable. While trying to reinstall the outdrive, I ended up chewing up the inside of the new bellow, around the inside of the rim.<br /><br />My questions is, is it OK to still use that bellow (I'm thinking the acutal seal is more to the outside of the lip).<br /><br />Also.. is there a "trick" to getting that dam drive back on?? Everytime I pull it, it takes me 2 hours and three guys to get the u-joint through the bellow.. after that it's fine. Just wondering if anyone had any tips on that.<br /><br />Thanks!!<br /><br />-David
