So here’s the story shorten up I just bought the boat 22ft with the 4.3l guy had it in water a year ago and ran great has service receipts and all kinds of paperwork. He told me it was water ready. I bought the boat took it on the water and was running great. I then smelled something weird and when I shut the boat off to go smell it I herd water boiling almost sounded like inside the motor but wasn’t positive but also didn’t see anything else that caught my eye. I was watching the gauges and I had Over 40 psi oil pressure and also had the temperature going up around 180 but when I shut the motor off and noticed that the temperature kept going off but when driving for about 15-20 minutes it was fine I wasn’t going any higher. When does start Boat found out it wouldn’t turn over got it back home took out starter. starter tested good, motor was seized but still could turn it a tiny bit from a
screw driver on the fly wheel. I then proceeded by taking the spark plugs out and found out that water came out of cylinders 2 and 3 I believe across on each side. My question is I would like to rebuild the motor from top to bottom but I’m not sure where to start or is it better to just rebuild the top end because the motor sounded fine. I also can buy a motor that runs from my car same motor 4.3 L same year 1987 has everything with it and runs for 350$
