Where are the water drain plugs on omc 120 hp with omc 400 sterndrive
No announcement yet.
Omc drain plugs
bottom of intake manifold - probe port with a screw driver
bottom of engine block, port side - probe port with a screw drive
remove large hose and drain - may need a hose pic to remove hose.Cheesehead boating the Gulf Coast of FLA 27.51° N, 82.53° W
1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - https://forums.iboats.com/forum/owner...988-rogue-2420
Past Boats
1970 Wooster Hellion - Merc 9.8
2002 SeaRay 190BR - 5.0 - A1G2 - "Cheeseheads in Paradise"
1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
What’s behind you doesn’t matter. – Enzo Ferrari
- 1 like
Originally posted by C3KNIGHT View PostWhere are the water drain plugs on omc 120 hp with omc 400 sterndrive
You'll find the manifold drain on it's bottom, 'bout center, or slightly aft of center,.....
It'll either be a 1/8" pipe plug(7/16" wrench), or 1/4" pipe plug(9/16" wrench),......
Just below it at the bottom of the block, just above the oil pan, is the block drain, a 1/4" pipe plug,.....
'n pull the big hose off the circulatin' water pump on the front of the motor,.....
It hides 'tween a pint to a quart of water,.....
The drive,..?? Lower it,....
- 1 like
If you did a lot of boating in muddy shallow water, make sure the lower foot drain holes are clear.
If the drain holes are not clear, you may have to pull the outdrive, and separate the halves to clean out the cavityCheesehead boating the Gulf Coast of FLA 27.51° N, 82.53° W
Past Boats
iboats Boating Forum Directory
Over 100,000 Questions & Answers
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Activities and Destinations
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats (250+ Manufacturers)
Bayliner Boats
Sea Ray Boats
Zodiac Boats
