Hi, i have the oil pump tube Jam inside the Hole off the oil Filter, imposible to remove, if i broke the tube inside i thing its not good to run engine with tube inside the bloc so if someone have suggestion to remove the tube or if i need the remove the oil pan.. i need to remove engine from the boat.
dont ask me why i put the tube inside this Hole sometime we dont think so long, the tube is 6 inch inside the oil hole.
Thank for your help !
