So I have the plastic version of the OEM OMC transom shift cable tools.
i have installed a new transom cable before when I still had the points dist. Using the tools and the real OEM manual everything went fine.
Finally decided to ditch the points dist and grabbed the Delco EST kit. Same thing replaced new cable with tools. Followed the Delco instructions to hook up to the stumble switch.
Put in the water and at ideal forward and reverse shift perfectly. BUT forward no problem at all. Reverse idle it will shift into and out of gear correctly. BUT if I give it any gas in reverse it instantly dies. I did notice that the detent part has a lot of play shifting forward. Reverse it’s sitting right on the stumble switch.
Gonna re read the manual as it’s been a while but I think o need to take a little away from the forward part and give some more room for the detent part for when it’s in reverse.
Or should I remove the out drive and start all over again ?
Much thanks for any advice
happy boating
happy boating
