platinumedge
- Aug 12, 2018
- 93
This boat has a Volvo-Penta combination with a 5.8L EFI Ford engine. I removed the engine last week (no real problems), but really just raised it up enough so I could re-insert a couple of freeze plus. I lowered it back down most of the way and got the bolts started in the front engine mounts. Then I lowered it the rest of the way so the rear mounts lowered over the studs, and got the lock nuts started back there. I then torqued all mounting nuts/bolts to their specs. Everything seemed fine.
I have been taking pictures of all the "little things," like smaller bolts, screws, and fasteners, as I go. However, I neglected to take pics of the rear engine mounts prior to removing the engine. Yesterday I noticed that the number of threads protruding above the locknut on the starboard rear mount was significantly less that the number threads showing on the port mount. I removed the locknuts again, just now, and I can't see, nor feel, any gaps underneath. Is it "normal" for the engine to be "shimmed" up higher on one mount? I'm assuming the factory makes these types of adjustments due to boat manufacturing differences, but wanted to ask you folks.
Thank you kindly.
P.S. The alignment tool slides in just fine!
Thank you kindly.
