Hello, I’m new to this forum. I have a 1989 Four Winn’s Horizon with a 4.3l OMC cobra.
I recently had the engine rebuilt. It starts up fine and runs fine, but when I check the heads with my infrared thermometer they measure way hotter than the block and intake. On the first trip out on the lake the heads got up to 240 and I shut it down in fear of blowing a head gasket or cracking a head. The big hose going to the circulating gets pretty hot, and the engine will make gurgling or boiling water sounds also when the heads get that hot.
The block runs around 160 on the gauge and with my thermometer.
I have changed the impeller, the impeller housing gasket, circulating pump on the block is new, thermostat, and o-ring are new. The exhaust manifolds are brand new so no clogging there.
I have water flowing up from the outdrive to the thermostat housing, and water exiting out the transom.
I’ve done a leak down test. Checked out ok. I did it with thermostat housing off and didn’t get any bubbles.
I am am kind of at a loss, and I don’t know what else to check. The engine builder is not being any help and kind of blowing me off. Is it possible he installed something wrong like head gaskets or intake gaskets that are causing my problem?
Anyone else ever have this issue and how did you solve it?
Thanks in advance!
Thanks in advance!
