Mbishop412
- May 23, 2019
- 9
I have a 1992 5.8 OMC Cobra. I had a fire last year. The solenoid melted, as well at the connection to the starter, and the positive battery terminal. I installed a new starter, new battery, new relay solenoid, new alternator, and new wiring. After approx 5 hours of normal operating, the solenoid cracked down the middle. The positive wire, to and from the solenoid, were extremely hot. I cannot figure it out. The solenoid is self grounding with a bolt through the motors frame. The only issue I see is the previous owner bypassed an ignition wire. Theres a straight wire from the ignition key to the solenoid. It doesn't not go through the neutral safety switch or harness.
This is the second time this has happened. Both times were after approx approxmins of constant full speed cruising. Stopped the boat. Idled. Turned it off, sat for a few mins, and when going to restart is has a very low, slow, drowning type of attempt to start. Does not start, check the compartment and see the solenoid relay terminals are starting to melt out and the wires are extremely hot to the touch.
Biat is a 1992 Four Winns 225 Sundowner
