ab59
Ensign
- May 10, 2017
- 979
I'm slowly getting this starcraft back together again and need to install the new gimbal bearing . The 5.7 is still out of the boat and I want to install the bearing then the outdrive and dunk the boat to check the new transom for leaks BEFORE I reinstall the engine again.
I have a bearing install kit that you drill a hole in the alignment bar and fix a bearing sized disk onto the bar and drive the bearing into place.
I have not installed the pivot or bellows yet and have only the gimbal housing looking out .
Would there be any problem in doing this without an engine to help guide the bearing into place or am I good to go ?
I have read that many do not like this type of bearing installer tool but it's what I have and what I will be using .
