How’s the 4.3 1988 Mark twain 23 footer the boat starts right up runs great after about an hour ,then you go to give it throttle and you got nothing it’s bogs down and it will not idle you wait about 10 minutes it’ll start right up and runs perfect again ,,I have change to The wires and plugs, fuel filters for some reason I believe it it sounds like it’s not getting fuel I think it could be the fuel line Or the coil I like to buy a coil I heard I can Buy them from Napa, it still has the points in it I’m just getting tired every time I take it out to the lake it dies on me and I will not idle and this is probably my fifth boat I’ve had in 20 years,, but when it runs it really runs good and I did rebuild the carburetor myself . I bought this boat middle of August this year guy claims that have 15 hours on a crate motor not sure though , Like I said I have a feeling that it’s either the coil or the rubber gas line because when it won’t idle it seems like it’s starving for gas but when you hit the throttle you go look in the carburetor and it does shoot gas down pretty good
