Trim on a '77 happens up at the front of the engine. That's what you're referring to as trim, correct?
If you put your hand on the sterndrive and push or pull, the drive will move? If so, the clutch pack still isn't right. Otherwise, sounds like your motor needs cleaned/rebuilt/replaced.
Welcome aboard.
