ab59
Ensign
- May 10, 2017
- 979
I have been chasing down a few leaks prior to splash time and although i have found most of the problem i still have a dribble that drips down from under the Y pipe but I am thinking it is the driveline bellows. I checked the Y pipe while the engine and outdrive were out of the boat and it looked fine but i did not remove it and replace the gasket and yes i know that was jackass thing to do but it just got by me. Let me say that i have a 350/Cobra sterndrive in my 1988 starcraft that had a 2005 sticker on it as the last time it was used . engine was blown and froze up.
Unless I find a way to examine the bellows without taking the outdrive back out then I plan on changing the bellows and now I am thinking about the bearing as well. I have no way of knowing when the last time these items have been serviced but would a bearing that sat for 13 years need to be replaced of since it had not been used would i even need to worry about it unless it starts making noise ?? I thinks that i already know the answer but wanted some input from those who actually know.
thanks,.
thanks,.
