Okay guys I'm a new boater, just got a 1988 Blue Fin with the 2.3l Ford. The boat runs fine, starts, cranks all the good stuff. The stern drive runs nice and tip top and all that jazz.
Problem: The oil keeps turning into milk. We pulled the head and did all new gaskets (head, exhaust and intake manifolds, water pump, valve cover, riser, and carburetor rebuild). We checked the manifolds for leaks and they seemed fine, the engine runs fine so that leads me to believe the compression is good.
I've yet to do a coolant pressure test but I am just sick of working on it so it's going to sit for a couple days. If you guys have any suggestions please help a new boater out.
I forgot to mention I seem to think the oil pressure 70 psi seems to be a lot and haven't been able to find much info on that.
Thanks from Michigan!
