PezzDSpenser
- May 13, 2012
- 8
I've owned the bout for 7 years now. It's in fantastic shape. Previous (1st) owner was meticulous. Dry docked it, was never left in water for more than a few days. I've docked it every season on Lake Ontario. The bilge has always been dry unless it rained. Last fall during winterizing the service tech recommended replacing the bellows and gimbal bearing. It was done. This spring I launched the bout. Took the 10 minute ride to the dock. Put up the canvas and hooked up shore power. Upon checking to make sure the battery charger was working I heard a steady light flow of water. Looking further it was coming from the lower area of the transom plate. Pulled the boat and took it back to the service center. A couple days later they tell me they checked the boat in the pond and then filled the bilge on land and the leak is coming from the transom seal and I'll need the transom replaced. Apparently the transom seal during this generation (87-92) of Four Winns OMC & Mercruiser are famous for this issue and the service center has a history with this being a Four Winns dealer. If the bilge has been dry all these years, is it common for it to just dry out over the winter (always in heated storage) and then all of a sudden leak this bad. My other thought is the service center really messed this up because I have this issue and the outdrive now whirs pretty loudly when in gear. Curious on thoughts and feedback. Thanks.
