Hallo i need advice about omc King Cobra. I have boat with King cone clutch Outdrive and i want to convert it to sx dp. Transom hole is the same what about coupler transom plate .... any help would be wellcome
The Cone Clutch King Cobra was never used with the 460
All the SX drives use an engine mounted raw water pump.One item not specifically mentioned so far is the raw water pump location. If you go prop-to-pulleys it does not matter. But an SX duo-prop has raw water pump on the engine and the Cobra series has it in the sterndrive. The posters thus far are not saying it explicitly, but trying to "just" go to an SX with same engine may be problematic in that area.
