froggy1150
- Nov 3, 2017
- 796
I am the proud new owner of a once used boat trailer. it came with a free 1974 21 ft rinell cuddy w/ 190 hp ford 302 and I was told it couldn't be restored..... challenge accepted! the owner was replacing the carpet and it sat..... 10 years. it was a salt water boat. so first I have read anything that seems to apply here, I have made it thru about 200 of 298 pages. purchased seloc manual-seems to suck. I have so far fixed all the electrical, rebuilt the carb, repaired the tilt motor and clutches and freed up the frozen steering shaft in the intermediate housing that was jammed pack with what seems to be salt rock (10 hr adventure). I have started the motor and runs well. I only ran it long enough to test the drive for a second. it shifts into fwd and rev fine with no horrible noise. so now I am in process of rebuilding upper and lower. I have both seal kits and water pump with both drive shafts. the upper has been a bear to get apart so far, everything has been frozen and I am down to the horizontal shaft w ball gear. its FROZE in the housing. any tricks to getting that out or just keep working it til it comes free? and it will come out with balls attached? all n all though this seems to be a really easy simple drive to work on (my first boat ever owning and working on). so any tips and tricks or things to watch out for and not learn the hard way while rebuilding this drive other than whats in the seloc manual?
also I cannot find a single pic of what the cabin is suppose to look like to put back together. so if anyone can direct me ......
