Hello all.
OK.... real quick.
1) Pulled the clutch pack from the tilt mechanism. Oil came out. No water.
2) Everything looked really good, but... on one of the clutch plates some of the teeth were a little damaged or bent.
3) I am not really sure how this thing works so can I clean these up (I could file them down) or should I look to replace them?
4) Also I found what looks like a "ring" about halfway between the size of a dollar and a quarter ( it was broke) and very thin. Is this a spacer/shim? I have seen these taken apart and I have not seen this before.
Anyway thanks for any advice.
Jim
OK.... real quick.
Jim
