While trolling through Ebay, I came across seal kits available for the upper and lower units. Given my boat has been out of the water 5years, is this something else that should be done? If so, how laborious is this (ball park)?
Frank, You don't have to reseal a Cobra unless it's leaking. (either oil leaking out or water getting in)
Like Lou mentioned, the ESA doesn't usually doesn't fail. You can test them with an engine running by actuating the system manually. It should cause each engine to "lope" (The ESA actually "pulses" the ignition to produce the torque pulses sufficient to separate the "dogs")
That torque holding those dogs together is only present when the boat is in the water (I.E. there's a [water] load on the prop) This means if you try to test it by shifting the drive on the trailer, the ESA will not actuate. (there's no load on the prop when it's spinning in air!)
Also, the ESA(s) should only actuate when you are coming out of gear. (It's not needed to place the drive in gear FWD/REV) AND if it does actuate when going into gear, your lower shift cable or shift mechanism in the drive may be binding.
proper adjustment is EVERYTHING with a dog-clutch Cobra. Adjusted properly, they shift into and out of gear reliably. Adjusted wrong, and you have the risk of permanent damage.
None of us here want to scare you ..........but
basically 2 things will "kill" a Cobra (aside from driving it into the rocks!) ...............A maladjusted shift system AND filling the drive wrong....(with oil) The former will damage the shift dogs in short order and the latter will destroy it with only one trip around the lake.
A Lot of times we get people here asking questions after the damage is done! It appears you are here before all this can happen!!:thumb::thumb:
