blackwaterstout
- Aug 28, 2005
- 146
My '79 Johnson has a cotter pin that holds a cone shaped prop nut in place. I removed the prop yesterday to grease the shaft and assembly and it came off quite easy. My problem now is that when I tighten the nut back up against the prop the cotter pin hole does not line up. The only way to get the cotter pin hole to line up to to have the prop nut slightly loose. Is this acceptable? Seems like a poor design to me.
