Welcome Guest - Sign Up today
No announcement yet.
Converting 2003 suzuki DF25 to DF30
  • Converting 2003 suzuki DF25 to DF30
    I was told that the specs for a DF25 is the same as a DF30 and to increase HP I would require a new CDI unit. Is there anything else that I would need in order to increase HP?
    Best, Dan
    What specs? Several different HPs can share the same Bore and Stroke, but that doesn’t mean a lower HP can be converted to higher HP cheaply. 5 hp is only about 1 mph faster top speed
    what you need to do us a Line by Line comparison of both engines parts list. Then and only then will you know what is different.
    • #3
      Is that a 2 or 4 strokes motor ? If both shares same CC powerhead it's a matter of checking both model's spare parts to find out which parts are common to both models and which needs to be swapped for new 30 HP parts for a correct upgrade.
      Happy Boating
      Sea Rider 320, 380 Sibs, 450 Rib, 2 Strokes Tohatsu 5,18 & 30 HP Proud Smokers
