OK, as so often happens in outboards, ie, Stator plate, Timing plate, trigger, exciter coil, charging coil, and about a dozen other terms for what is under the flywheel, mostly for the same electronic components, we are not using the right term I guess. IT would not be a skeg guard or prop guard as many companies make those. The correct term would be replacement skeg. (for portable outboards) I have only found one maker in Australia, none in the US. IF I am wrong, let me know before I start a business that would make HUGE dough, if I am right.
