. I came here to see if anyone would but was put down by a know it all factory timing is 17deg and I run 30deg BTC and my 25hp will run with 40hp Yamaha on the same boat... simple modification running the 70hp for nine years and the 25hp for 6yrs.. Found here 98% guess and retest.. No actual good step by step and a 2 stroke is so simple.
Would what ?
What is a know it all factory timing ?
Yes, two motors mounted on the same boat will be traveling at the same speed.
I look forward to you contributing your actual step by step.
I was told I need at least a 90 hp my boat, but if you can help me to get my
Evinrude 50, 2 cycle 2 cylinder running faster, I'm sure it will do fine.
I am particularly interested in the rpm your 25 is turning.
