ShoestringMariner
- Apr 18, 2015
- 1,563
Hey folks, I've got a CMC PTT that I bought used. I'm mounting it on my aluminum boat (1975 Starcraft SS160).
The manual I found online states that the cavitation plate needs to be mounted 1-3" higher than the bottom of the boat due to the 6" setback of the motor from the hull. But also warns not to set it too high that I lose water pressure at top end
So, how can I be sure I have the optimum height set up? I heard that for every inch of setback, it should be 1/2" of rise. By this rule, it sounds as if the motor should sit 3" higher than its original position which is on the top end of what the manual recommended.
I don't want to have to re-drill holes in my newly rebuilt transom if I get it wrong. It does not have a jackplate. Do you guys think I should air on the side of caution and go only 2 to 2-1/2" higher or am I worrying about this needlessly?
