I understand that is not a good idea. True??
I have an 18 year old Tohatsu 30 hp 2 stroke that has not been unhappy running on E10 (as long as I keep the gas fresh and stabilized).
But I needed to buy a gallon for reserve, and was non ethanol.
I've kept it separate, didn't need it at the time, and wonder if I should use it now.
Only a gallon so no big deal, but using it is the easiest way to "get rid" of it, if that doesn't cause problems.Can I run one tank dry, run the Non ethanol tank dry, then back to my E10?
