robert graham
- Apr 16, 2009
- 6,908
Is Pennzoil still manufacturing this 100% synthetic outboard oil, and if so, where can I buy a few gallons?.... Seems everywhere I've checked lately they've been out...
XD 100 is synthetic and TCW rated
Last time I looked at the label on the jug, I didn't see a TCW certification
Pennzoil does make synthetic blend, which is $18/Gal at Wallyworld.
Jim, so you like smoky and stinky, when the OB runs?
Nothing like a light aft breeze, the slow rocking motion from a tight chop and a lung full of outboard smoke to get the chummers hanging over the side...lolI like the smoke, it confirms the engine is still running, it smells great, and it keeps the Mosquitoes away.
It say right on the label for use in direct inject and oil injection systems.Being that the XD100 was intended for the DI engines, perhaps it might not be the best choice of oil to be mixed with gas. It may have been formulated not to mix with gas easily as it intended to be injected into a dry crankcase.
Way over kill unless you can take advantage of using at 100:1
Not TCW (pay to play) because it’s not marketed for general use
and lots of 10w30. Used that stuff all through high school. Yeah it smoked, but the motor ran. The only problem i ever had was fouled plugs, and that was after I had some money and bough some Texaco Outboard Oil. Boy that stuff was crap.
I still have the old Merc and she still runs.
