What is a 1998 2 stroke 4HP Mercury outboard worth?
bruceb58
Going to sell said outboard. What are these things worth? I am going to list on Craigslist and/or eBay. Also, any suggestions where else to advertise?
Down here in land of gators you would get $600-700 for it. In the land of beer and cheese, you would get about $400
bruceb58
Did a NADA search and low retail is $325...average retail is $400. Since use of 2 stroke here in CA is an ocean use only, I am thinking closer to $300.
you could ship it here and list it in FL
Texas Prowler
Would you mind doing a compression test before you sell it and post results here? I'm currently in the process of rebuilding my 98 merc 4 hp and could use that info. Thanks! How's it run?
bruceb58
It runs great. I will do the compression test. Any idea what it's supposed to be?
alldodge
This is the second way of selling something on iboats that doesn't get flagged. The other way is to do a build thread then list all the parts you want to sell and links to CL items
Stumpalump
I thought mercs were sold by weight?
Texas Prowler
I really could use this info could we please keep the jokes to a minimum. Hate to see this thread go dead. Thanks!
82rude
When you say 2 strokes for salt only do you mean all or just carbed?
Sea Rider
Tohatsu same HP ones if happens it's a rebadged one should have 78-80 PSI max after 5-6 vigorous rope pulls with carb's butterfly opened fully. Check if in that range or more. Sometimes Service Manuals have misprints. My 2 strokes 18 HP was max 106 PSI rated and read 120 PSI after the compression test.
Happy Boating
82rude
That's what I figured also,just making sure.You know you can get efi small generators now,wonder how long it will be before all motors with few exceptions go efi.
Texas Prowler
Happy Boating
Mine had a solid 90psi before I took it apart for a rebuild. I'm sure it was more from the factory. I'll find out after the rebuild i guess.
thatone123
Banned
Up to 15 hp nationwide, the used price for good condition ones is about a $100 a hp. I have had some 25-35 years old 15's that are showroom that went for $1600/1700, one never was even outfitter with a prop...Some 4's showroom condition that went for $550/600
