In most of the "industry" when there is NO units expressed, you would normally assume rms *(eg 120VAC is in rms)............If otherwise, it is normally explicitly stated, eg., ww
DVA, xx
Vp, yy
Vpp, zz
Vavg,
see tohatsu's
LINK pg's 7-6, 7-15, 7-34, you'll see units being expressed in their listed measurements
Yes, 2-3 amps would be fine, inrush from that cap should be so fast, 1A fuse shouldn't be able to react, if so, 2-3A would hold.
* May be converted to Vp by Vrms * 1.414 = Vp due to that this conversion is derived for sinusoidal wave forms only..... And thus, not all Vrms measurements can be accurately/predicatively converted to Vp by Vrms * 1.414 = Vp. e.g., triangle, saw tooth, white noise, pink noise, Mercury CD ig. waveforms etc, etc...
