Re: using dynamat on underside of cowling?
This topic is of great interest to me also. I have a pair of 175 Mercs, 1992 vintage, sitting on the transom of my 25 foot WA fishing boat. The noise level is not bad, but I would like to make it even quiter. I put up a post on the Merc section on this topic several weeks ago, titled Noise Reduction.<br /><br />Based upon responses to that topic plus my own research, I plan a two prong attach of the problem. I plan on building a cover over my engine motor well and lining the under side with sound deadening foam, the idea is to stop sound waves from coming straight at me from the engines.<br /><br />The other part of the potential solution is to put more sound deadening foam in the cowlings. There is some there now, but I will measure to see if additional can fit. One wasted area is the emergency rope starter stored in each cowling, I will remove and replace with sound deadening foam. It will be necessary to ensure that no foam can come loose and get sucked in to the air box. I might try to make a screen for over the airbox inlets.<br /><br />I will follow this tread to see if anyone has additional info.
