Welcome Guest - Sign Up today
No announcement yet.
gas pump/siphon recommendations?
  • gas pump/siphon recommendations?
    I need a cheap siphon/pump to get gas out of an inboard boat(four winns 190 freedom) before cutting it up any suggestions on something cheap but will work well?
    Re: gas pump/siphon recommendations?
    why not just cut the boat up from around the tank. Take the tank and knock a hole in it and drain.
    Assault Squadron NINE
    River Assault Division NINETY-ONE-1966
    • #3
      with my luck it will explode if I touch it with a feather xD I would also like to have something that works just in case I get some bad gas in my good boat and to take some out at the end of the season before adding the stabilizer and winterizing.
      • #4
        This is what I used to drain mine:
        http://www.walmart.com/ip/Performanc...ndingMethod=rr
        The reviews on it where horrible but I figured for $9 I had nothing to loose. Shoot alittle oil or wd40 in it to prime the seals and it worked perfect for me. It also comes with an oil change tube. I have done two oil changes with it also. Its paid for itself already in my book.
